Author Topic: Observing tonight?  (Read 371899 times)
Mr.Gorp
  • Member
    • View Profile
Re: Observing tonight?
« Reply #1950 on: May 27, 2017, 05:47:29 PM »
Anyone for Keller Sunday Night?  (if it clears up).
Mike C:\
  • Member
    • View Profile
« Reply #1951 on: May 28, 2017, 08:17:26 AM »
I would be interested in going. So far weather looks good. Maybe some clouds around 1am.
Thanks
  • Member
    • View Profile
« Reply #1952 on: May 28, 2017, 03:46:25 PM »
Jupiter's Red Spot and Io's shadow at 9 pm!   I'll likely stay at home however to observe ... depends on how late other obligations go.
Bob
Bob Fealey
Josef Ch
  • Administrator
  • Member
    • View Profile
« Reply #1953 on: May 28, 2017, 07:36:57 PM »
Looks like it could be reasonably clear Sunday toninght, and talking to Bob, I will go to Keller.
  • Member
    • View Profile
« Reply #1954 on: June 02, 2017, 10:29:08 AM »
Two clear nights in a row!  A June 1st observation of Jupiter appears below.  Jupiter was from a video with 47 images stacked in RegiStax6 to reduce noise.  A single, overexposed tif image was used for the moons.  I couldn't get my Starry Night program to show the moons and the planet like they appeared in the eyepiece and camera; the moons were shown on the other side of Jupiter but the red spot was as shown below??? in Starry Night.
Bob Fealey
darkskyjim
  • Member
    • View Profile
« Reply #1955 on: June 02, 2017, 06:56:20 PM »
nice image Bob!
  • Member
    • View Profile
« Reply #1956 on: June 05, 2017, 04:07:01 PM »
Thanks Jim!   With the moon approaching full but the skies being clear Jupiter, Saturn and Venus (and possibly nearby Uranus) remain good targets!
Bob
Bob Fealey
  • Member
    • View Profile
« Reply #1957 on: June 06, 2017, 11:30:23 AM »
Io and Europa were quite close last night, kinda like a wide double star in appearance.  Over an hour and a half or so moon movement with respect to each other could be noticed.  Seeing conditions were fair.  The image attached was taken around 10:35.  Some image stacking was used for Jupiter and the moons were recorded on a single image with Jupiter overexposed. All was put together in Photoshop Elements.
« Last Edit: June 06, 2017, 11:38:09 AM by titanicrivers »
Bob Fealey
johnattewell
  • Member
    • View Profile
« Reply #1958 on: June 06, 2017, 12:11:33 PM »
Bob:  Is "Photoshop Elements" something different than "Photoshop CS?"  If so, is it easier to use than CS (CS is pretty complicated)?
John
John Attewell
Rochester, MN
  • Member
    • View Profile
« Reply #1959 on: June 06, 2017, 12:52:01 PM »
Hi John!
Photoshop Elements is a stripped down version of Photoshop.  It's not like Photoshop CS.  It's also a lot less expensive than Photoshop or Photoshop CS.  I have been using Photoshop Elements (PE) for the last 12 years or so and think it's great.  If you are a enthusiast and not a professional in the publishing field than PE is for you.  As with all programs there is a learning curve to negotiate but its easier with PE.  I use version 14.0 and don't have a need to upgrade to the latest version 15.0.  You should be able to find it online for about 60 -90 dollars.
Bob
Bob Fealey
  • Member
    • View Profile
« Reply #1960 on: June 07, 2017, 08:23:51 AM »
Still learning how to use Registax 6 with the Orion 5MP camera.  Online tutorials on You Tube help a lot.  Jupiter was a good target last evening with the Red Spot in good position.  Seeing conditions at 8:56 pm were pretty good and a 2 GB video was taken and stacked in Registax 6, a free program.
Bob Fealey
Randy H
  • Club Officers
  • Member
    • View Profile
« Reply #1961 on: June 07, 2017, 10:07:33 PM »
Pics are getting better all the time Bob!
  • Member
    • View Profile
« Reply #1962 on: June 15, 2017, 11:44:52 AM »
Thanks Randy.  Couldn't miss the opposition of Saturn earlier today as the skies were clear (although the seeing was only fair to good).  Just after midnight conditions were good although the humidity was high.  The B ring was especially bright and Cassini division was visible almost all around the globe. A 2 GB video was used for the photo which was again processed with Registax 6.
« Last Edit: June 17, 2017, 10:19:58 AM by titanicrivers »
Bob Fealey
  • Member
    • View Profile
« Reply #1963 on: June 15, 2017, 07:09:58 PM »
For those of us wanting a precise polar axis alignment to true north (about 43' away from Polaris) tonight is the night for using Clay's Kochab Clock!  I am posting the link in this forum note.  The alignment should be done around 9 pm tonight June 15th.
Here's the link: http://arksky.org/Kochab.htm
I'll test it first.
Bob
It worked for me but google-it if it doesn't for you.
BTW this link and method is already included on the RAC web page under the 'Resources' tab.
« Last Edit: June 15, 2017, 07:34:52 PM by titanicrivers »
Bob Fealey
  • Member
    • View Profile
« Reply #1964 on: June 20, 2017, 12:35:52 AM »
Io, Europa and Europa's shadow on Jupiter are shown in the stacked image below.
Bob Fealey
